Re: Is TA 140 too high?
CarlD
MAY is the key word. If you use bleach you should not have a problem. I have had several seasons with T/A in that range and didn't have a pH rise.
But if you use cal-hypo you'll probably see pH go up--I RARELY use cal-hypo, preferring to use Di-chlor if I'm going to use dry chlorine.
What I suggest is you run your pool using bleach/LC and see if you are fighting rising pH. If so, lower T/A. If not, swim and have fun!
BTW, I'm assuming you have a vinyl pool. But if it's concrete/tile/plaster, you should keep T/A below 120-125, so lower the T/A.
Since it's gunite, what should be the desired TA level and how do I lower it in the quickest way?
BTW, my poolskimmer creates air bubbles. Would this aeration affect the pH?
This is my ticket for Heaven (when all's working..) :
22k Gal gunite IGP
38 SF DE filter, 1 HP Hayward Super Pump
Raypak 350k BTU Natural Gas Heater and solar cover
8 gal Liquidator with bleach
Dolphin robotic cleaner
Taylor k-2006 test kit
