Re: Ascorbic treatment
It took awhile but I got a copper test kit these are the numbers on the water today.
CC=.2 FC =4 PH=7.3 Alk= 110 Cal hd=150 CYA = 110 copper .8
The stain is back as bad as it was when I started.I appreciate the suggection offered. Since our summer abruptly ended,no one is swimming in the pool. I found another source for ascorbic acid at Essential wholesale and ordered 5 pounds. Is there any way to determine how much sequestor I need to use when I do another ascorbic treatment?
