Results 1 to 10 of 36
Thread: Taking control of my pool this year
    jilted is offline Registered+ Thread Analyst jilted 0
    Jun 2011
    Louisiana
    Exclamation Re: Taking control of my pool this year
    OK I used my Taylor kit this evening. Pool has been running since Sunday night after adding ~8 lbs of CYA.
    FC: 7.5 ppm
    CC: When I added the 5 drops, it did not turn pink. Is this OK?
    pH: 7.6
    Alkalinity: 90 ppm
    CYA: around 35 ppm
    So I still have some work to do on my CYA i guess.
    How about that CC issue? Should this have happened?
    I guess I'm off to find more CYA this weekend since our Lowe's doesn't seem to have it. Would a feed store possibly have it? I live out in the country hehe.
    Thanks,
    -stephen
    26,500g inground vinyl liner (new liner installed June 2013)
    Hayward 1.5 HP Super Pump - Hayward sand filter (sand changed in spring 2009)
    Compu Pool CPSC36 SWCG - Polaris 380 cleaner
    Default Re: Taking control of my pool this year
    Quote Originally Posted by jilted View Post
    Absolutely!! If it didn't turn pink, that means you have no CC, and that's the whole goal!! Your other numbers look pretty good, other than the CYA still being too low. A feed store probably will not have CYA, but if you have a Tractor Supply Co (the chain) nearby, sometimes they do. Otherwise, go to WalMart and check the section where the spa chems are.
    Jun 2011
    Louisiana
    OK Walmart had the HTH brand that was a 4 lb container of 96% CYA for like $14
    Went back to Lowes on the way out and they DID have CYA this time heh.
    Our Lowes has the Aqua-Chem brand and it was a 3 lb container of 100% CYA for $13
    I had already bought the HTH and wasn't going back in that madhouse.
    Is there much of a difference in the two brands being 96% and 100% CYA?
    Anyway, I put another 4 lbs in which should give me maybe another ~15 ppm which would bring me to 50. Should I try to bump it up a tad bit more?
    Thanks,
    -stephen
    I wouldn't add anymore CYA yet. The 4 lb. addition should add about 18ppm more of CYA which would put you up to about 53 which is in range suggested by your SWCG manufacturer. You can always add more later. Easier to add more later than need to remove.
    Jun 2011
    Louisiana
    Thanks. So now that I have my CYA under control, about where should I try to keep my chlorine level at? I think I read that since the SWCG is constantly producing chlorine that you can keep it lower than if you were using granules and tablets.
    Also, is there a consensus on when I should run the pump? Day or night?
    Thanks,
    -stephen
    Read your literature that came with your SWCG. It should give you the chlorine levels needed for your system. I run my pump during the day. Some people do nights because electricity rates are cheaper then. I am not too familiar with SWCG operation, so let's see if one of our SWCG guys has any opinions on this and why.
    Jun 2011
    Louisiana
    I'll check. This forum has been a wonderful learning experience so far. I appreciate the knowledge I have gained! I already have a friend emailing me to come test his pool!
    So I'm getting down to basics now as most of my tougher issues seem to be getting resolved.
    -Is there a rule of thumb on how many hours to run the pump? A friend in Texas that has a pool said 1 hour per 10 degrees of pool water is pretty close.
    -For a "true shock" I should use liquid chlorine bleach, so how many ppm should I try to raise it by for it to be effective? Also, is it best to "pre prepare" the pool (set the SWCG to 100%) say before a party when you know 15-20 people are going to be in the pool?
    -Regarding shocking the pool, should it be on a regular proactive schedule or reactive to things like heavy rainfall?
    Think I am getting close to knowing just about everything I wanted to know about my pool!
    -stephen
