Results 1 to 10 of 12
Thread: New Member & New Pool Owner
    Aug 2012
    Manteca, CA
    Default New Member & New Pool Owner
    My wife and I recently purchased a house in Manteca CA, along with the house came a pool full of green water & algae. I read through a lot of the posts here regarding how to get rid of algae and I seem to have killed all of it. Now I can't get rid of the brown dust like remains. I have brushed the pool three or four times a day and kept the filter running continuously for several days and the water, while no longer green, is still cloudy. I'm not sure if the pool filter is actually doing its job? The filter is an American Products DE filter and frankly...the idea of taking it apart to clean it or "fix" it scares the beejuzzes out of me. :-)
    11x32 rectangle 8K* gal IG concrete pool; Bleach; American Products DE filter; 1 speed pump; 12 -16 hrs; solar heat; HTH 6 Way test kit ( from Walmart); utility water; summer: none; winter: none; Wireless network & a laptop; PF:15
    Default Re: New Member & New Pool Owner
    Hi, and welcome to the forum!
    Is your filter pressure rising as your pump runs? Do you have the ability to vacuum to waste?
    With a DE filter, any particles should be collected. Since that's not happening, you know your filter needs service. It may be as simple as taking apart and cleaning it, or it may be require repairs.
    If you can post pictures (Photobucket, Flickr, Webshots, Picasa -- or email them to [email protected]) and/or exact make & model, we may be able to help.
    Aug 2012
    Manteca, CA
    1) Yes the filter pressure is rising when the pump runs. It goes up to about 23 psi, since the whole thing is new to me I don't know what the pressure was when the filter was newly cleaned consequently I don't know if the pressure has gone up the 10 psi or so that would indicate a cleaning is needed.
    2) I don't really have the capability to vacum the bottom. I do have a polaris 360/280? that sweeps the bottom but from what I've seen this is designed to pick up leaves and other debris not fine particles. I have been brushing the sides and pushing it towards the filter pick up at the bottom of the pool and this seems tp help, but in the morning there is always a layer of brown dust/particles on the steps, I do have the ability to run the polaris and the filter at the same time and that might explain why the bottom of the pool seems clean but the steps are not. I'll try to post some pictures. Before I purchased the house I had a pool inspection done and everything was at least functioning, BUt the inspector could not verify if the filter was actually filtering. The pool inspector was very impressed/stunned by the amount of pvc plumbing and valves the previous owner had installed. With that in mind I have not figured out to actually get water up to solar heater on the roof yet. :-)
    If you have the HTH 6-way DROPS test kit -- not 'guess-strips'! -- post complete test results.
    Also, you need a manual vac system -- everyone does. Do you have a working skimmer?
    Aug 2012
    Manteca, CA
    Using the HTH drop tests...
    Ph = 7.5
    Clorine = 5-10 ppm
    Alkalinuity = 70 ppm
    The only chemicals I use are Bleach, Borax and Baking Soda.
    What are your calcium hardness and stabilizer levels? Those are also in the HTH 6-way. (Well, actually, it's total hardness in the HTH, but close enough.)
    Aug 2012
    Manteca, CA
    Todays test results...
    Ph = 7.5
    Alkalinity = 80 ppm
    Clorine = 3-6 ppm
    cya = 50 ppm
    Hardness = 600 ppm
    Aug 2012
    Manteca, CA
    Today's readings...
    Clorine = 2-4
    Ph = 7.5
    Alkalinity = 70ppm
    I still can't get rid of the brown dust. I was looking at some of the battery operated sweepers but form what i've seen these just pick up leaves. Do any of these have the capability to filter fine particles out of the water?
    Quote Originally Posted by Green&Slippery View Post
    You need a manual vacuum, not a battery operated on.
    It's also possible that your DE filter is 'leaking' DE. If you touch the "brown dust" and it has some texture, it's DE. If it's fluffy, and you can't feel it, it's dead algae.
  1. New Member with New pool
    By LarryW in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-29-2012, 01:28 PM
  2. New Member, yucky pool
    By Old Bat in forum Intex-type Pool Setup & Operations
    Last Post: 07-09-2012, 05:40 PM
  3. new member, new pool
    By dawgster in forum Pool Equipment & Operations
    Last Post: 02-08-2012, 06:04 PM
  4. New member and pool owner needs help.
    By mastamoon in forum Dealing with Algae & Slime
    Last Post: 09-16-2011, 05:44 PM
  5. new home owner -- new pool owner -- clear as MUD
    By Andyman33 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-06-2011, 07:51 PM
