Results 1 to 10 of 18
Thread: Filling pool with firehose???
    SeanB. is offline --General User-- Weir Watcher SeanB. 0
    Missouri City, Texas
    Default Filling pool with firehose???
    A friend of mine has access to the tools and firehose to connect to the firehydrant outside my house. He said he has refilled his pool this way in only about 40 minutes and has offered to let me do the same when filling our new pool.
    My concern is that this will obviously be a very high volume and pressure stream of water. Would it be safe on the new plaster to fill the pool that way? I was thinking that maybe I should let it fill about 20% with my hose and then put in the fire hose so that it would just be pushing against more water and not directly against the plaster. Thoughts?
    Site owner -- www.troublefreepool.com
    Sugar Land, Texas
    Default Re: Filling pool with firehose???
    Could you lay a big blanket on the bottom of the pool, put a sheet of plywood on top of the blanket, a couple of cement blocks on top of the plywood (so it won't float), and then let the firehose blast away against the plywood?
    Pool owner - contract signed 21Aug2006; HOA approval granted; complete - existing patio demolition; excavation; rebar; embedded plumbing; gunite; plumbing; electrical; tile and coping; decking; plaster; pool fill; acid start-up; regular start-up; pool school; gas meter upgrade; additional of salt; PDA remote programming.
    Jakebear is offline Registered+ Thread Analyst Jakebear 0
    Jul 2006
    Pennsylvania
    I hope you checked with the municiple water authority (unless you plan a "dead of night filling"
    They will, at the very least, want to charge you for the water. I believe there are also some laws on the books which prohibit you from doing this too, That is why the job requires some special tools.
    Sorry to be a "kill joy" but what is right is right
    27038 Gallon InGround, Vinyl, DE filter.
    Scottsdale, Arizona
    you'll be sorry with all the dirt and contaminates you get from that line.
    duraleigh Guest
    SeanB,
    If you have the other issues worked out, dirt from the line will not be a problem. I fill my pool from my pond......the dirt and junk get filtered out in fairly short order. You'll need quite a bit of chlorine.
    Eljefe's idea worked for me. I layed a 4x8 sheet of plywood on the floor of the pool (with concrete blocks on top) and allowed the water to fall directly onto it. It diffused the blast nicely. I was not smart enough to use the blanket....that's a nice precaution.
    PS - If the other issues are not worked out, you may want to check the quality of the food at the county jail before proceeding further.......or perhaps your spouse can bring you some fried chicken on Sundays.
    I like Eljefe's idea. That should give adequate deflection.
    Last I checked, they don't lock you up for misdemeanors, although fried chicken does sound pretty good. Don't worry, I've got my bases covered.
    Sugar Land, Texas
    Does this make me a willing accomplice?
    haze_1956 is offline ** No working email address ** Thread Analyst haze_1956 0
    nj, usa.
    So Fast, So easy, Order Yours, TODAY !!
    Quote Originally Posted by eljefe281 View Post
    I aint no stoolie!
    Quote Originally Posted by haze_1956 View Post
    I see you found my supplier.
    Classic.
  1. New pool is filling up now...so confused on what to do!
    By colleenebeans in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-11-2013, 12:15 AM
  2. Pool pump not filling all the way to the top
    By cynjam in forum Intex-type Pool Setup & Operations
    Last Post: 06-05-2012, 09:28 AM
  3. Filling a new pool in the cold?
    By Pibster in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2012, 06:56 PM
  4. Filling the pool after plastering
    By JonnyG in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2006, 02:11 PM
