Results 1 to 10 of 16
Thread: Cloudy water
    May 2012
    Indiana
    Default Re: Cloudy water
    Pool store said my ph was 6.5. Pool calculator website says to add 6 boxes of Borax. I added 3 yesterday and tested 6.8 this am. I have added 2 more boxes and am waiting to test later this pm. Everyone says not to worry about the chlorine and cloudiness until the ph is 7.4 so I stopped adding bleach and waiting for stabilizer to increase. Should I leave my pool covered during this process? I have an automatic cover and have been keeping it closed but another thread on here said to open pool and try to aerate it. I have bought all Borax at our small town Walmart and I still need another box. I hope the pool stores ph test doesn't stop at 6.5 but when I used my test kit from walmart it looked closer to 6.8 at noon. I am waiting on my Taylor K-2006 kit to get here soon.
    Hi Ann;
    1. Do NOT trust the pool calculator website on pH effects -- the pH calculations are often wrong, in ways that are difficult for me to explain.
    2. Stick to the 2 boxes and test -- that will work.
    3. The K-2006 will not test lower pH levels, but if you want to, you can do the "acid demand" test, which will allow us to determine if you are a little below 6.8, or a lot.
    4. Unless you want your "cloudy blue" pool to turn "cloudy green" do NOT stop adding bleach daily. If it turns green, recovery will be MUCH harder!
    5. If borax is not available, dose with ONE box of Washing soda at a time (instead of two boxes of borax).
    You need to learn to distrust the pool store more . . . or you'll end up a victim again.
    May 2012
    Indiana
    Just tested again with HTC chlorine/ph tester from walmart and the chlorine is now 1-2 and ph is not quite 7.2. I can now see the fourth step in my shallow end. Does this mean it is slowly clearing??? Thinking about adding 1 more box of Borax. Any advice?
    Quote Originally Posted by wardenann View Post
    Just tested . . . ph is not quite 7.2. I can now see the fourth step in my shallow end. Does this mean it is slowly clearing??? Thinking about adding 1 more box of Borax. Any advice?
    1. Yeah, add the box.
    2. If you couldn't see the step before, then it's probably clearing.
    3. Continue to maintain chlorine levels -- no matter what.
    4. Once you have the K-2006, report test results.
    Since your pH is on the move, I'd add a half a box instead of a full box. Then see where that takes it and then you can decide if you want to add more.
    May 2012
    Indiana
    Today added 1 box borax at 1pm and by 5pm it had raised ph to 7.2 and chlorine is in 2-4 range. Backwashed twice today but pool still cloudy. Opened cover and created a way to aerate with garden hose!!! Now, how long til pool clears??? I have P.O.P. in an IV so I am much calmer today!!! Plus weather got colder here and my salt water pool friends all have cloudy water this year. Everyone is blaming it on the mild winter in the Midwest!!!
    OOPS! Our crystal balls are all broken today. Sorry!
    BigDave's Avatar
    Crystal ball is cloudy?
    As long as you can get chlorine in the pool, then I would open the cover. Aerating the pool will also help raise the pH.
  1. Cloudy Water
    By PoolConfusion in forum Dealing with Algae & Slime
    Last Post: 07-23-2012, 08:51 PM
  2. Cloudy Water
    By joserq in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 01:01 PM
  3. Cloudy Water
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 11:49 PM
  4. CLoudy Water
    By Sunshine427 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2008, 03:57 PM
  5. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
