Re: Cloudy water not clearing
I just went out and tested the water. Chlorine still very orange. I added ALOT last night, but no luck. Anyhow, I brushed it again. The CYA is still around 30, but the dot disappearing test is very subjective. I'm not sure if they mean totally disappears or starts to fade in color. If it's the latter, my CYA might be higher. I retested hardness again. Still none indicated. I also took some pictures. Will send in a minute. I am not the best photographer but they may help. Thanks again.
